Under the dash re-assembly sequence, not sure how to explain this, but what should go first under the dash to make the process go as smooth as possible. I am thinking while dash board is off to get the new wiring harness installed then the heater and all the hoses with that. In addition to that, do the defroster vents go on before or after the steering bracket? I would think after because the heaters were an option, but what about the vent alignment. I am also thinking is it possible to but the steering wheel and shafts on with the dash out of the car and the slid the dash in? I am asking because it is so much easier for me to have access with dash out. In the past, I have installed the glove box much later, so I can look up in there better. It has just been so long since I have replaced everything under the dash, I was hoping to learn from others mistakes.
steve
steve
