BUCKEYE_BOB
The undercoating on my MGB is all cracked up from age and heat, it was an Arizona car. I want to remove the undercoating to ensure there is no rust under it. What is the best way to remove it. The only way i can think of removing it is lay on my back and scrape it of. (All ready stripped the top side of the floor boards and only found surface rust and i will repair that). Once I remove the undercoating should new undercoating be applied? I will drive the car only in the warm weather.
