Randy Forbes
I *try* to put them where the outriggers meet the chassis. It works pretty good on the right side, and it used to work on the left side, but then I put the exhaust system on...
Now, with a combination of wooden blocks, it is on the outriggers outboard of the exhaust. So far, nothing has wrinkled :wink:
I put ten (10) or twenty (20) BMWs on my lift for every time the Healey goes up for a ride, so it's not worth the trouble to me to modify the lift to suit the Healey. I get the car over my head, and it's secure on the arms for when I need to really tug on something, so I'm happy.
I will say though, I shortened the rear arms on my lift, because the wheelbase is so short (Healey or BMW) that I was hanging too much weight off the back. The carriages were going up the columns *cocked* and would've eventually wore out the rub-blocks prematurely. Now I can see the carriages staying pretty well balanced as the car goes up and down. I took just about a foot (12"<span style="text-decoration: underline">+</span>) out of the rear arms and welded them back together.
To ANYONE using a lift for the first time, or the first time you put a different car on it: I get the car rigged up the best way I can, ideally using the factory jacking points as a reference, then only raise it a few inches clear of the ground. At this point, I grab the front and rear bumpers, then the door posts (or what have you) and give the car a mighty shaking. I'd rather it drop a few inches to the ground than to crush me. Safety first!
