Two post lift
Michael Oritt
I'm sure this has been discussed a gazillion times over the last few years but I wasn't in the market then and thus was not paying attention.
What are desireable features, things to avoid, etc. I will be using it 99% of the time for the Healeys or Elva, but might want to put my Toyota Tundra up once in a while. What brands did you wind up buying and why?
I bought this one from Eagle: https://www.eagleequip.com/page/EE/PROD/LI-ETP/MTP-9F It was several hundred dollars more at that time (01/06) but included shipping.
With only a 9'3" ceiling, I had to use a floorplate type; if you have the height, I recommend getting one with the cables and hose run overhead, to allow for a completely clear floor. Seems whenever I'm pulling a trans out of an M Rdstr, I have to compromise on the jack location due to the "hump" covering the cables/hose. Of course, even that is still miles better than doing the job on your back!
About a month ago, one of the connectors for the hydraulic hose was getting a little damp, so I ordered a replacement hose, and at the same time got new rubber pads. Other than that, it has been trouble-free, and I use it A LOT.>
Another little talked about advantage of the lift, is being able to wax the rocker panels while standing straight up.; I just finished compounding/buffing/waxing BN6L-942 on Monday; sure wish there was a local car show this weekend...
vette
Michael, I do not have any personal experience yet but have been reviewing the possibility of buying one myself. Since I do not have more than 8.5 feet ceiling i have been looking at that possibility. There is a short post version that has post that are less than 8 feet. The post are actually portable but seemed to me to be very hefty. I believe the lift capacity was 7000lbs. It also did not have a floor plate. It would seem that this might be rickety but the post were very substantial. I'm sorry that I do not remember which company was supplying them. (years ago as a teenager I worked in a garage were we lifted cars with two air jacks, one front and one back. The air jacks had extended forks to reach under the cars.)
In talking with a mechanic friend, he recommended that if I were to buy one, that it would be wise to buy one that has the unequal length lift arms. With the longest arms (the trailing arms to the rear). This allows the post to be more forward in your bay and might allow some work in the bay without the car being between the post. It also keeps the post away from the doors when the car is in the air so that the doors can be openned.
Happy hunting,
Dave C.
Michael Oritt
Michael Oritt
Dave--
Thanks for the info. Luckily I have plenty of ceiling height.
big6
Michael,
I have been researching two post lifts for some time and have decided on a lift manufactured by Greg Smith Equipment. In my opinion this lift will meet my needs and priced under $2,000.00. The particular model I am considering is their Atlas OH9000. The specifications are below…
Capacity 9,000 LB.
Lifting Time Ask Your Salesperson
Overall Height 140 ½" (11' 8 ½")
150 ½" (12' 6 ½")
Overall Floor Width 132 3/4” (11’ 3/4”)
Outside Column to Outside Column 124 ½ (10’ 4 ½")
Maximum Lift Height 72 7/8" (6’ 7/8")
(With Adapters) 82 7/8" (6' 10 7/8")
Minimum Pad Height 4"
Inside Column 111 ¼" (9’ 3 ¼")
Column Size 6 3/4” x 10 5/8”
Column Thickness of Steel .150”
Drive Thru 96 ¾” (8’ ¾”)
Base Of Lift 15 5/8” x 15 3/4”
Cable Diameter .367"
Motor 2HP, 220 Volt, Single Phase
Shipping Weight 1,460 LBS.
Greg Smith Enterprises has a location in Norcross GA in the Atlanta area fairly close to me. I plan to drive to Atlanta and pickup the lift in December. Another location is in Delaware closer to you.
As Randy indicated earlier, an overhead cable system allows for work underneath the car without the cable enclosure in your way. I have enough ceiling height in my garage to easily clear the 12’ 6” taller height. I built my garage with the lift height as a design consideration.
My only concern is the minimum pad height of 4 inches for the BJ7 but it is not a problem for the TR6 or the 330CI. The pad height is consistent with other lifts that I have considered.
I enjoyed the Hunt Club Classic last October and meeting you and the other DC area club members… I have a project in Winchester, VA that will be installing in October 2010. I will try to make the 2010 event also.
BabaKahawa
Big Question:
I have read all of the reasons for looking into a two post lift.
I too am looking to have a place to work on autos more efficiently.
But, why not a four post lift system, they are about the same price and you can
store two cars in one space??
Four (4) post lifts are good for parking on, but the 2-post variant allows unobstructed access to the undercarriage, and immediate access to remove wheels, work on suspension, brakes, etc.
A 4-post lift requires the use of a rolling jack (or tray) between the rails if you want to lift the wheels off the runners to remove them, then you have to do your work while reaching across said runners (though I suppose they'd make a good place to lay down tools).
I regularly store two (or more) cars in the space under my 2-post:
This shot best illustrates why I used a photocell type of interlock on the pump motor; when the beam cannot be bounced back to the controller by way of its reflector, the electricity is cut from the motor via a contactor.
Michael Oritt
Michael Oritt
OK--Last question:
The "ideal" lift for me would be the Eagle 7000LP which has the following features:
1. 12' ceiling clearance (No problem)
2. Assymetric post setup (Saves on garage width)
3. Ultralow ground clearance pads (2")
4. 7000 lb. capacity (I will only be lifting small cars)
The MTP9A has the following features:
1. 12' ceiling clearance (again no problem)
2. Assuymetric post set (Same deal--no problem)
3. 4" (Standard) pad clearance
4. 9000 lb. capacity (more than above)
I don't understand why the lower clearance pads should cost so much---and I assume that both models have quality American-made cylinders.
Can anyone explain the big difference in price for that one feature, and that on a lift with lower weight capacity? Please go to the Eagle website and compare the 7000LP to the MTP9A--maybe I am missing something.
Thanks in advance.
Just a hunch, but the 7000LP may be (nearly) 100% American made.
The construction of the arms would not warrant the price differential, but Chinese to American labor could. Compare with their Bend-Pak prices.
You'd think they would be promoting that fact...
Lin
Okay Randy,
What is the material that BMW uses as a thermal screen between the floor pan and the exhaust? Sure looks a lot nicer than Dynamat Extreme!
Lin
BabaKahawa
Randy;
Nice info on the 2 post lift. It looks like you have the posts attached to the ceiling of your garage.
Is that true??
They're aluminum stampings; real honest to goodness shaped panels. They're embossed at the mountings, so that they maintain about 1/4" airspace between the heatshield and the floorpan.
They're pretty thin, and easily deformed, but likewise, easy to straighten back out again.
Another shot, this being a Z3 version of the M Rdstr:
Michael Oritt
Michael Oritt
Randy--
Your answer as to what the difference in price between the Eagle 7000 LP ($3599)and the MTP9A ($1499) is due to was 100% correct: The 7000 is made in the US whereas the MTP9A is made overseas.
Michael Oritt said:
Randy--
Even a broken clock can be right twice a day. :wink:
Given unlimited (or even more than comfortably available) funds, I'd buy the American made, but other than a weeping hose, I've had no trouble with my import.
I did however, shorten the rear arms by about 10-12" to allow the majority of the car's weight to sit more evenly between the columns, as I was concerned about uneven wear on the rub-blocks. I guess they really don't have our short wheelbase cars in mind during the design stage.
BabaKahawa said:
Randy;
Is that true??
Actually, no.
They lied; where the lift is installed, the celing height is 9'3", and the specs on the columns were 9'3". In reality they were more like 9'4-1/2", so the 2 x 10 floor joist is notched and sitting on the column. I am not concerned about it having weakened the floor, especially as it rests on the column.
Somewhere on my "to do" list is dressing those openings off with some trim, but it likely won't happen until the house is made ready to sell...
Jerry
I have been looking for a two post lift on the West coast. I see lots of used ones, but I worry about potential problems and pointed out on other threads, I don't want to under the car when I find a problem with the lifting process. I may go the the Sacramento Autorama this year. They usually display a few there and might be able to save on shipping.
Like someone else above, I hit the double nickles next year and find it harder to crawl around on the floor as I used to.
Anyone have a West coast brand or source that sthey like?
Jerry
Lin 4-post lift hydraulic fluid Austin Healey 5
Trevor Jessie Small four post lift Spridgets 9
R 4 Post Lift part #2 Austin Healey 2
R 4 Post Lift Austin Healey 17
S 4 post lift Restoration & Tools 14
Stinky looking for a 2 post lift Triumph 6
R Need Input On 4 Post Lift Austin Healey 2
Stinky 4 post lift vs. 2 post lift? Restoration & Tools 19
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
P TR2/3/3A Block treatment post cleaning Triumph 17
jlaird MGB Don't post like I did 10 years ago. MG 7
EWD TR6 74 TR6 - “ A Post Seal” Triumph 0
jlaird MGB Follow up to my bad post on prewar MGs MG 4
Gliderman8 Editing a post FORUM Navigation Questions 6
F General Tech trouble with editing post Triumph 2
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
B TR6 New Member, first post Triumph 1
S TR4/4A B post to sill Triumph 5
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jim_Stevens For Sale Post-60K LH door Triumph Classifieds 2
R General Tech How to attach pic's to a post? Triumph 1
R Adding attachments to your Post FORUM Navigation Questions 1
tahoe healey past post about sholder belt foam Austin Healey 2
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
D Test image post FORUM Navigation Questions 1
ckeithjordan TR2/3/3A Apple Hydraulics vs White Post Restoration Triumph 13
M battery helmet stuck on post help Austin Healey 8
T Trouble inserting pictures to post FORUM Navigation Questions 2
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
PeterK TR4/4A From a VTR post on Facebook. Herman has passed. Triumph 16
Lin Post in float bowl came loose Austin Healey 6
NutmegCT battery post connectors Restoration & Tools 6
S TR2/3/3A The door and B post hardware Triumph 3
R TR2/3/3A "B" post Triumph 7
Tinkerman TR2/3/3A 1960 3A post 60,000 top installation Triumph 6
Rut 2 post lifts Spridgets 18
Randy Forbes HMN Blog post about AHS 3610.... Austin Healey 6
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Got_All_4 TR2/3/3A Need Pic of a Post TS60000 Occasional seat Please Triumph 5
T How to post photos? Spridgets 6
J TR4/4A Answer to my post "help with tr4 transmission disassembly". Triumph 9
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
CJD TR2/3/3A Screw Post Coils Triumph 6
S This internet article/post made me laugh... Austin Healey 5
AUSMHLY Can't post photos, why? Austin Healey 0
Basil At an Indian Trading Post Spotted 1
