My BN7 has two 6-volt batteries located along side the differential, same as the BN1 and BN2, connected in series.
The location is awkward to say the least and it is easy to overlook the maintenance.
The two 6-volts batteries expired recently and I have to replace them.
The cost of each battery is about NZ$ 350, I am up for about NZ$750 for two.
A 12-volt battery that will fit in the limited space available is about NZ $ 175, which would be a big saving as well as the advantage of no maintenance. If I put a single 12-volt battery in where one of the 6-volt batteries goes, either the positive lead or the negative doesn't reach the battery terminals. As well as that, the CCA of the 12-volt batteries is 330, so I need two of these to give me sufficient CCA.
I thought that the easiest way to solve this would be to fit two 12-volt batteries in parallel. This would let me connect the positive and negative terminals and give me a combined 660 CCA.
I tried this out and the result was a failure. The ignition light comes on and the headlights work, but as soon as I hit the starter button, after turning the headlights off, the engine cranks over for a few seconds and the the ignition light goes out and there is no power.
I checked the fuses and they are all intact, so I am at a loss to know what is going on. All connections are tight.
I am thinking of reverting back to two 6-volts in series as this system worked perfectly well, but I am intrigued as to why the problem exists. It is almost as if the CCA are not double that of a single 12-volt battery.
Any suggestions as to the cause would be very welcome.
Crusty.
Crusty.
