That down-tube carries the oil from the cam troughs back into the sump... it's problematic. I've always been liberal with RTV on both ends of it when assembling an engine, seen plenty of 'em leak. If you clean it well and get it (and surrounding area) clean/dry, you MAY slow it down some by smearing RTV around the base... a "stop-gap" fix at best but it may hold until you can R&R the head, down the road.
