Brosky
I recently decided to install my newly rebuilt and recurved distributor with Igniter inside(Advanced Distributors, LLC) and the new Flame Thrower Coil. I also put in new Magnecor Race Wires from Moss and new NGK Iridium plugs. I jacked up the timing to 14 degrees at 900RPM with a total advance of about 36 degrees at 2800RPM.
Thanks Jeff!!! My car runs like a bat out of you know where now. I'm really pleased with everything from the distributor work and coil to the new wires and plugs. I did the work incrementally and each addition made the car run a bit better, but the biggest change came from the recurve and the new plugs.
I had been running Bosch Platinum plugs and was very happy with those, but there is a noticeable difference with the Iridiums, since they were the last item changed.
Now if I could only locate a nice bright red distributor cap it would look as good as it runs.
BTW, no affect at all on the radio with the Magnecor wires.
