I have a 1973 TVR 2500M and I'd like to either rebuild the motor or swap in a new one. I have quite a bit of oil burn, but 125 psi across all cylinders and a good leak down test. I'm guess the valve guides are shot. I have 70k miles on the car.
Should I try and rebuild the engine? Swap in a new one? If I go with a new engine, what should I put in? Where can I find one?
John
John
