Woodie
Yahoo they work... But why. ??
I changed my emegency flasher switch and emergency flasher relay last night, checked all the connections for the flasher bulbs. Then checked the voltage and had 12 volts across 1 green wire at the flasher switch. The signals did not work. I switched on the flasher and only the passenger side lit up, but did not flash. Then while trying to figure this out, the green white wire pulled out of the connector under the dash. AND THEY WORKED?? The emegency flasher does not but all the signals work. If I plug the green white wire back in, I am back to only the right side lighting up, but not flashing when the emergency switch is on. I was confused but happy. Rather have signals than not, and who needs emergency flashers, they just waste precious battery power. So today I drive to work happy with turn signals, but when I get here a coworker who followed me in says "hey your passenger rear tail light is out". Oh OH, thats green white I say to myself....ELECTRIKIME...gotta love this stuff. NOT !
