Jim_Gruber
I'm in the process of wiring my BE Bonnet on Bugsy my '68 with a quick disconnect so bonnet can be removed as needed. Got headlights working but when I went to try to get turn signals going thingsd aren't working. Crap. I tried flashers, they work fine at the rear. They don't work at the front. Try turn signals, no turn signals at the rear, hmmm.
Get out the VOM. Check wiring back at the bullet plug before quick disconnects and it is showing like maybe .5volt as lamps try to flash. Now since I had the radio console moved out of the way last week to replace the choke cable, I'm thinking I pulled something loose where the turn signals feed from the Emergency Flasher circuit. Someone tell me my logic is correct here. Radio Console is a PITA to pull out and get behind.
