Spitfire Turn signal wiring Spitfire
Richardspur
1974 Spitfire lefthand drive. Trying to figure out wiring for the turn signals. Colors are faded, can someone post a picture of the wires coming down the steering column and plugging into the correct wires below the dash. I have some female ends that have a place for two wires to plug in and just can't get it figured out. Thanks.
Yes, the colors should match, but on my recent (two o three years ago - or more) puchase the colors are different. The green white seemd correct, but the cooors of the remaining wires were confusing. I had to use a test light to determine the proper connections. I checked the Haynes diagram and it shows a different color for later cars.
T. T.
T.T.: That seems odd (except for the fact that the reference is from Haynes, not always known for absolute clarity and accuracy! ;) ). All wiring diagrams I've looked at, including several very nice ones found at Triumphspitfire.com, show the colors as I noted above. The only other color that comes to play for the flasher circuit is a light green w/brown.
