Matt Mugherini
Member
Recently picked up one of the early turn signal switches with the optional high beam 'flasher' built into the switch. Currently, the car has a worn original turn signal switch with the dimmer/high beam switch located on the firewall near the clutch pedal.
Couple questions:
1) Wires on the new switch match up perfectly with the old (including a black ground wire with bullet connector), except that the new switch has what I believe to be an additional ground wire, which ends in a metal circle clip- just like the grounding wire for the rear lights, etc. that bolts to the inner trunk body using the license plate bolt. Does anyone have a picture of the switch install (steve s.?) or could tell me where the second ground wire should fasten?
2) I assume that I can leave the floor dimmer switch in place without modification and that high beams can now be flashed from the floor switch AND the stalk, as appropriate. Anyone believe otherwise?
Thanks!
Couple questions:
Thanks!
Hi Guest!
