BlueRidge1
Hi Guys,
As I was stopped at a traffic light I noticed in a reflection of my car in a store window that it appeared the left rear turn signal was blinking. I checked the lever and it was in the center position so upon arriving at my destination I investigated it further and this is what I found.( the car is a 62 3000 bn7 non adjustable steering)
1 Signal in off postion resulted in a steady blink though not as strong as a normal blink and only on the left rear.
2.Lever in left turn position and I get a normal blink front and rear.
3 Lever in right turn postion I get normal right flash front and back and the left blinks in the rear at the same steady flash as the right side. The left front stays off.
4 parking lights all fuction normaly.
Any suggestions? It had been working fine for the past 18 months .
Thanks Bob
Thanks Bob
Sounds like you need to adjust the brake switch overiding relay. It's normally open but for some reason it's making slight contact. Lift the cover off the relay, (left Driver side front fender), check the number 3 terminal see fig. N20 on page N14 in the shop manual. Something is causing the flasher relay to operate on the left rear, short maybe?
