turn signal knocked off center
ah60_68
switch 1.jpgswitch 2.jpgswitch 3.jpgI have somehow managed to knock my turn signal (trafficator) in my '60 BT7 off center. Now it does not want to stay on for a left turn. I tried to just twist the switch back into place but no go. Is there a way to fix this without taking the whole thing apart? Where could I find some detailed instructions for fixing this? Thanks...
red57
Loosen the nut & olive on the front of the steering box, turn the trafficator (turn signal switch/horn push) where you want it and re-tighten the nut & olive.
Be prepared for a bit of the steering box oil to seep out. Also, one thing I 'discovered' while doing extensive work on my BN2's box was to leave a bit of a gap--1/32" or a bit more--between the trafficator 'dome' and the steering wheel hub. If you place the trafficator against the hub the hub will likely rub the trafficator when you turn.
MikeAH100M
I also found it helpful to have a second person hold the trafficator/horn assembly in place while you re-tighten the nut on the steering box. It keeps it from twisting with the torque.
crya
Hey all. Longtime lurker and infrequent poster as life gets in the way sometimes.
Anywho, I've had this exact same issue for a while but didn't want to get into it. Here's the newest newbie question. How the heck do yall get to the Olive/nut? I shined a light through my grill and see the box and nut right there. Doubt you can get at it from top. Do you guys have a procedure you can share? Seems like popping out grill would be most direct access but how does one do that? I can't see another way. Not from below I hope.
Cheers and thanks ks
On a 6-cyl car I believe you do have to come up from below as the wheel inner shield prevents access from the side (just put the front left on a jackstand). If you loosen the olive you'll probably get some leakage of fluid from the box.
bluegrass john
I am not sure if the problem i have is exactly the same as the others in this thread, but it may be and I am wondering if the fix is the same!! The trafficator assembly works well but it moves slightly left and right as the steering wheel is moved...........movement is not very much but aggravating. I wonder if the olive nut can cause this same situation? Hope I am not changing subject!!
Thanks,
John
steveg
Thanks,
John
If you have the adjustable steering column, there could be play in the telescoping tube setup. It's a crude dimple that slides in a slot so it gets worn over the course of decades.
bluegrass john
OK Steve..........news to me but sounds like a problem solver. I will check out the parts manual to educate myself. (if possible)
Thanks for giving me a lead.
john
Also, the slot the 'dimple' slides in is cut square at the end, and will develop stress cracks. The slot really should have had its corners radiused.
crya
Ha! I didn't realize once I just crawled under bumper there's plenty of room to reach up to the nut. This thread fixed my problem as I too was able to readjust my trafficator! Sweet. Thanks.
John Fautz
My 1967 Austen Healey 3000 has a similar problem. I'm tightening the brass nut that should be keeping the horn/turn signals stationary but it still turns independently from the steering wheel. I'm afraid if I tighten it too much that I'll damage something. Any suggestions would be appreciated. Maybe it needs a new "Olive"? Seriously.
red57
If the olive is missing/bad you would most likely have oil all over unless the box was filled with cornhead grease. I suggest you get under the car where you can clearly see the short piece of tube that extends out of the nut & olive and have someone turn the trafficator back & forth a ways. If the tube is turning then the problem is probably the olive. If the tube doesn't move when the trafficator is moved the the problem is most likely the dimple or the slot mentioned above.
I'm tightening the brass nut that should be keeping the horn/turn signals stationary but it still turns independently from the steering wheel. I'm afraid if I tighten it too much that I'll damage something....
Just to be clear, the steering wheel and hub should turn and the trafficator--turn signals and horn button--should remain stationary. I've found that you need to leave a gap between the backside of the trafficator and the front of the steering hub; at least a sixteenth of an inch or so else the hub can rub the trafficator and attempt to rotate it. You can torque the olive reasonably tight; I'd guess about 10-15lb-ft wouldn't hurt anything. The olive nut is brass and the front plate of the steering box is steel so worst case you'd ruin the nut. I've also noticed that once torqued down pretty well the olive can develop a 'shoulder' on the taper that wedges into the front plate, so, you can usually torque the olive twice--once on each taper--before needing a new one.
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
D TR2/3/3A Turn signal cancel? Triumph 11
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
