Turn Signal Indicator
SaxMan
I've been having a hard time locating a replacement turn signal indicator light socket on Baby Blue -- Mine is a 2-wire, and it seems all the sockets from the usual suspects are just one wire. I managed to cobble the old one back together over the winter, but something went very wrong today. Not only did the indicator stop working, but a short took out my tach, fuel gauge, turn signals, brake lights, heater fan and windshield wipers. Still have to go diving into the dash, but I think it is one of the inline fuses that blew.
I was on the DC Beltway going to pick up my daughter -- not exactly the place where you want to be when you lose turn signals and brake lights. I first noticed it when the fuel gauge was going down. At first, I thought I had ruptured a fuel line, but there was no smell of gas, and when the gauge dropped below "E", the engine was still purring away. When I glanced over at the tach and saw it at zero, I knew I had an electrical problem. I did the standard "reach under the dash and jiggle some wires", but to no avail. I still did have my headlights and radio. I was able to manually flip on the headlights so that the running lights would simulate brake lights, and used hand signals for the first time since Driver's Ed.
Once I picked up Jessica in Tyson's Corner, I took the back roads so I was just one exit away from crossing into Maryland. I got out on the highway long enough to cross into Maryland and then bailed out onto the back roads. Incredibly, on almost the entire trip home, I had no one running up close to me. The couple times I did, I would pass through an intersection and the light would change and the car behind me had to stop, clearing my rear. Someone was looking out for us this afternoon.
Similar things have happened to me in my '67. Both times, it was the fuse(s) that were dirty. Pulled them, wiped them off, blew the "fuse block" clean, re-installed, and (knock on wood), things returned to normal.
Definitely the turn signal indicator. I hodge-podged a repair over the winter and it came undone. The short blew the fuse. Once I replaced the fuse, almost everything went back to normal, but the flasher fried as well. If someone has a turn signal indicator socket that they want to part with, please PM me:
The faulty indicator:
DSC_0066 by David Cohen, on Flickr
Yup, I'd say that fuse is blown:
DSC_0068 by David Cohen, on Flickr
I may have one. I'll be home tomorrow, and I'll check then.
Will this work for you? If so, just pm your address.
Rut
PM Sent - sure looks like it.
SaxMan,
Mailed out yesterday.
Rut
Thanks, Rut! I'll keep an eye out for it.
Rut was kind enough to send me the replacement turn signal indicator socket. The hardest part, of course, is doing the contortionist moves to work under the dash with the steering wheel and seat still in. The new socket spliced right in and fit like it meant to be there. The only hiccup was the replacement flasher that was sent was a three pin unit when it should be a two pin one. No worries, that will get exchanged quickly. I suppose I could manually operate my turn signals with the stalk if I really wanted to take the car out.
The other thing I discovered is that I now have to use reading glasses to work on close in items in the car. Without the reading glasses, I couldn't focus on the existing wires to strip them so I could splice in the new socket. Getting old is a bear. :wink-new:
Proper flasher was dropped off at my work today. Of course, this is my early day where I have to pick up my daughter from school.
Shouldn't be too difficult, but my left thumb (and I'm left handed) is in a splint for the next few days. I had a cyst form in the upper knuckle. While this was certainly better than the initial diagnosis of a bone spur and the onset of arthritis, getting a cortisone shot directly into the knuckle was one of the most painful things I've experienced...and I've had surgeries, been in accidents, crashed on my bikes and more fill-in-the-blank-oscopies than I care to remember. I had to lie down to keep from passing out. You don't realize how much you use the thumb on your dominant hand until it is immobilized. Should be off on Saturday -- just in time for more rain :mad-new:
