T-Series Turn signal headlight dimmer switch question?
Newkie
Let me preface the question with I have a 73mgb roadster.
I just received my dimmer switch from LBCarCo (Moss Motors part no. <span style="font-weight: bold">141-830</span>)and have a question or problem, depending on the answer.
The one I ordered has a different plug set up than the one that came with the car. The new one has 4 male plugs (3 on one side, 1 on the other) and 4 females (2 on each side).
The old one has (8 male with 4 on one side 3 on the other and one in the front centered) Did I order the wrong one, because I see the one I ordered says RD from <span style="font-style: italic">(c)267110 to 328100</span>
the others are <span style="font-weight: bold">141-820 </span>RD to <span style="font-style: italic">(c)267109 </span>and <span style="font-weight: bold">141-840 </span>RD from (c)<span style="font-style: italic">328101</span>
My cars number is <span style="font-weight: bold">GHN5UD 320423 G</span>, so unless I am totally wrong with the way you order these things, it should have the right connector for the switch.
Thanks
Art
I will try to post some pictures tomorrow, since I am not having any luck with just descriptions. Still havent figured out how to yet, so I will try later...
Until then, have a good weekend. We are heading over to the Maddog and Englishmen show at the Gilmore Museum in Kalamazoo Mi. It has always proven to be a nice show for me as you get to look at more than MG's and Triumphs.
Thanks
Art
Never mind, I talked to John Twist today at the Mad dogs and Englishmen show (which I might add was alot of fun) and apparently I ordered the right one, but only if I had the right one on the car in the first place. PO must have changed it out at some time?
Art
