Warren - Does this happen on both left and right or on just one side? Are the indicator lights on the dash working and are all four turn signals working? Finally, are the signals blinking at the standard rate or are they flashing fast? It really sounds like you may have a short in one of the lines to ground and when that line is energized, it is dragging the voltage down, causing the tach needle to dip. Good luck - Dave
