Turn indicator switch???
nomad
The little plastic spring for the Mk 2 Midget's and Mk3 Sprites turn signal lever/switch used to be available. The switch is still available but I sure could use the plastic spring that centers the lever for several that I have with deceased springs. Anybody know if they are still available and where to look???
Kurt.
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
Rob Glasgow Turn Indicator Austin Healey 17
T TR2/3/3A turn indicator bulbs Triumph 26
B Turn Signal Indicator Light Always Flashing Austin Healey 10
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
R TR2/3/3A Steering Hub Turn Indicator lever Triumph 7
sim Sprite 58 turn indicator problems Spridgets 10
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
S Turn Signal Indicator Spridgets 9
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
J Turn signal dash indicator lights Austin Healey 20
I TR6 TR6 turn indicator Triumph 1
Boink Bugeye turn indicator or signal... Spridgets 18
Anthony_S Turn signals and indicator light Triumph 11
S TR2/3/3A tr3 turn indicator Triumph 9
I Bugeye turn indicator light help please Spridgets 18
I Bugeye wiring help for front turn indicator Spridgets 13
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
Gearhead turn indicator bulb for a 74 Midget Spridgets 3
C Looking for replacement turn signal indicator bulb Spridgets 1
I turn indicator help Triumph 10
ooman Looking for dash turn signal indicator - '67 BJ8 Austin Healey 10
A TR2/3/3A TR3 turn indicator not flashing in car Triumph 8
jjbunn Turn Indicator Cancelling? MG 9
M Turn Signal indicator lens needed Triumph 0
hondo402000 LED turn signal indicator lamp Triumph 7
SCguy TR4/4A Tr4 turn signal indicator ligt Triumph 7
I TR6 TR6 turn indicator not working Triumph 1
I TR6 TR6 turn indicator Triumph 2
Tullamore Dash turn indicator. Sprite MK III Midget MK II Spridgets 1
P MGB 77 MGB Turn light dashboard indicator MG 9
Carlbanan56 MGB Mgb turn signals MG 17
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
bighealeysource Turn Signals Austin Healey 21
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
G Engine Will Not Turn Off Austin Healey 10
M Europa turn signal problem Lotus 7
