af3683
I'm taking a shot at adjusting my SU H6 carbs. I have a copy of the original TR3 manual as well as various instructions I obtained from the web. My problem is that I find the manual a bit confusing and instructions found on the web often use language that differs from the manual. For example:
Web: Loosen "throttle linkage" nuts
Manual: Refers to "throttle spindle connecting rod"
Web: Back out "throttle stop screws"
Manual: Refers to "slow running stop screws" and "throttle adjusting screw on each carb"
Web: Back our fast idle screw(s)
Manual: Refers to "adjustable screw which abuts lever"
Can anyone tell me if these terms are the same. I actually may only need to adjust my idle a bit, but I'm not even certain which screw is the idle adjusting screw. Thanks.
Art
Art
