Martinld123
I just installed and started tuning new Moss H6 100M, 1 3/4" carbs with rebuilt distributor. My car is a 1956 BN2 with all 100M upgrades, 100M cam, larger M pistons, stronger valve springs, air box. I have had a fair amount for success tuning these style carbs in the past but I seem to be getting an on off surging at idle. I started at 12 flats out but had to go to 16 in front and 17 in back carb to make the surging less to none. I must be doing something wrong but I am using all of steps to setup carbs like balancing, lifting pistons to see if lean or not. My gray area is how to use flats to get engine to run smoothly. So 16 or 17 flats out seem too much but engine runs best in this area. At that setting my exhaust has a random burble every couple seconds or so with no surging. In short it seems to be running way too lean at 12 flats out and best at 16 to 17. Any ideas? My old carbs ran best at 17 flats out too. Thanks Marty
