TomFromStLouis
I met a guy the other night who races his BMW 2002. He seemed to know a thing or two about carburetor adjustment, at least more than me. This is not a difficult achievement. All I have done to tweak my idle is turn the little screw at each one back and forth until the car sounded right.
His first recommendation was to replace the SUs with Webers, Webers being superior and not as finicky. Perhaps, but that is the kind of originality I choose to keep. He went on to describe what sounded like some easy to use adjustment aids that attach to the carbs and visually tell you when each matches the other in flow. This sounded more like the kind of gizmo I could use, but his description is several days old and beer was involved, so I need you guys to tell what you recommend along these lines.
If simply turning the screws until things sound right is all I ever need to know, please say so. But if dialing these things in a bit better is possible, please link to a product that is easy to use.
, Keep the S.U.s. Simplest carbs. for your engine. You could get a Uni-Syn , a gizmo that reads the vaccum, but using a length of flexible tubing can serve as well or better. Simply put, you place one end at the carb. throat, the other end at your ear, and adjust the carbs. until the pitch is even. There IS more to do, and surely more info. will follow from others. Unless you got plenty o bucks and want to spend them, stay back from the Webbers! Invest in a manual, READ and UNDERSTAND it. Save that buddy for hoisting a few beers!
--O'elrey
Nice swift edit
