tahoe healey
I had a spoke break on a chrome wire wheel. To get the spoke out you must turn the nipple and break the "seal" (heard the air escape). I know you simply use silicon to seal the nipple again. I think that is a PIA and requires removing the entire tire. With tubes I could slide things over to access the spoke nipple. A ten minute fix. To repair the spoke, must I remove all the silicon from all the spokes and re do or just the bad one? If I go back to tubes, I guess I must remove all the silicone??? And is there a protective rubber band that goes in before the tube?
Yes, I seem to break a lot of spokes. One a year maybe.
Thanks
TH
Thanks
TH
Hi Guest!
