TR6 tubing size '74-TR 6
Wike
Need to replace the black plastic tubing from fuel tank to carbon canister...seems it melted once upon a time. Anybody know what size it is..ID/OD? ....1974 TR 6
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
S TR2/3/3A flaring the tubing for the clutch MC Triumph 6
G TR4/4A Windshield Washer Tubing Routing Triumph 1
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
Lynn Kirkpatrick Brake Pipe [tubing] Replacement MG 9
VelodromeRacer Tubing to use to relocate fire ext. system? Racing 3
jmwuva05 BE screen washer tubing? Spridgets 5
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
G Split loom tubing source Triumph 7
L T-Series Clutch Slave Cylinder Tubing MG 5
Bill Redd TR6 TR6 washer PVC tubing Triumph 3
GregW Brake tubing, Reservoir to MC Austin Healey 4
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
