Tremelune
I'm putting a TSI starter into my Sprite. I ordered it over the phone and recieved the starter quite swiftly. It's a <span style="font-style: italic">beast!</span>
There seem to be a few not-so-drop-in changes for this starter. First: the electrical post is much larger than stock.
I put the (probably not stock) power cable in a vice and simply drilled out the center. There is less material there than I would like, but it should be enough.
The gears do not line up...So much so that I'm worried. While the stock starter is designed to connect with the flywheel from the rear and the TSI starter is designed to connect to the flywheel from the front...It doesn't look like it will mesh very completely with the flywheel. I don't think the flywheel is thick enough to cover that difference.
Has anyone ever installed one of these? My plan is to put it in and see what happens. Even if it works, I have fears of premature flywheel wear, etc...
