Trying to remove nut from exhaust
2wrench
Removed the exhaust pipe where it meets the flange at the
bottom of the exhaust manifold. Went back to the first
joint back and removed the brackets where pipes meet there.
Now pipes are soooooo old and, well, stuck, getting those
buggers apart is hellashish.
Maybe I'll go for the super duper magnet on the end of a
hose or something, before trying to pry these suckers apart.
Think of it as some kind of a fishing game....
Wanna go fishing, anybody???? Any other ideas???
poolboy
If that bolt gets into the muffler with baffles, forget about it; it'll stay there.
MGTF1250Dave
Aloha 2wrench,
Trying to run a magnet strong enough to attract a bolt and keep it as you retrieve it might be a real challenge as it will be surrounded by a ferrous metal pipe which will also attract the magnet. You may then have a bolt and a magnet in the exhaust pipe.
The easiest thing maybe to cut the pipe in an easily accessible place(s) and look the bolt. A muffle shop can weld the pipe back together or add a connector if necessary.
Good luck.
2wrench
2wrench
Some creative stuff, guys. Thanks for the thinking caps. I'll let you
know where my sword falls.
IanF
I'm really confused...
If any of the system is rusty, why bother to save any of it? Cut everything off. Replace with new.
What's the problem? :confuse:
angelfj1
2wrench:
I agree with Ian. Don't try to salvage any of the old exhaust system. That would be a false economy. A new standard system (mild steel) is fairly cheap and an old system could become a safety issue should leaks develop.
Good luck, fja
DougF
I would agree on replacement. But, if you had that super magnet, why couldn't you run it on the outside of the pipe and slowly pull the nut up the pipe?
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]why couldn't you run it on the outside of the pipe and slowly pull the nut up the pipe?[/QUOTE]
Possibly a rust and carbon build up on the inside of the pipe. Don't ask me how I know about that.
DNK
I love the title of this post.
Don't know how to rid from the exhaust ,but the driver seat is easy.
Hide "HER" keys. :jester:
Royal_58
Some of the magnet parts chasers have a non-magmetic shroud around the magnet on the wand so they don't stick to everything on the way to pick up the intended part. You might try that inside a piece of surgical tube and slide it in the pipe. Or a shop vac on the end of a garden hose and......
Suck it Up!
DougF
You can go to a local auto parts store and find a "grabber" tool with a flexible shaft. They are about 2 feet long, you press the end and 3 metal jaws extend out to grab the offending part. There is the chance that the nut is beyond the length of the tool, or you could push it away with it, but regardless it is a nice thing to have in the garage.
mikespain
The magnet in the hose pipe works:tried it done it and success 90% of the time.Make sure you don't push the nut into the muffler box(if there is one) so measure that distance first,and don't go beyond it.use a strong magnet FIRMLY attached to hose pipe or tubing(glued and bound) and you should have no problems retrieving it unless it has already dropped into the muffler if so leave it till you have to change the exhaust-can't damage the engine as is on the blowing side.If you can't stand the rattle(if it does rattle)then you know you are into changing the exhaust.
2wrench
2wrench
Success in retrieving a bolt!
Downside kinda bummer: Discovered there is still something else in there.
Have to open her up and go back in.
Bought a magnet tool at Napa. Fashioned onto it for extension a clear
plastic tubbing I had in the garage to siphon fluids and check it out
as follows:
Here's a slightly out of focus shot, (sorry), of the bolt I pulled out.
Looks like a newer replacement hardware of sorts. Seems kinda funny, cause
we were in dismantlement mode when it was supposed to have been lost.
Go figure....unless, of course, there was more than one slip and I wasn't
told of the second....anyway.....
And a slightly clearer shot shows the end of the magnet (tool). Notice the
red plastic sheath surrounding the end of the tool. Really helped, I think,
to push the thing down where it had to go without binding on the sidewalls:
Moral to the story: This is a novice's mistake. The next time I drop the
exhaust pipe from the exhaust flange on the motor, I'll cover the exhaust pipe
openings with some kind of tape....plug the holes with rags...something.
H Trying to Remove Thermostat Cover Austin Healey 3
D Trying to get back working on the 1974 Midget Spridgets 11
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
Trevor Jessie Trying out a camera mount... Spridgets 20
M Trying to Find a Family Heirloom Triumph 59
