crj7driver
I am finally getting around to putting my restoration back together. I am trying to put the rear suspension back together and can’t remember how the springs go. I have Moss “racing suspension” which lowers the car, but for proper alignment they recommend using an aluminum spacer on the rear spring to achieve proper ride height. BTW, I had this suspension in the car for 5 years before tearing it apart.
So my question is do run the aluminum spacer directly on the trailing arms, then the rubber cushion to the spring or do I put the rubber cushion on the trailing arm, then the aluminum spacer and then the spring directly on the spacer.
Thanks for any and all help. It is amazing how I can’t remember how things were on the car after 1.5 years.
