twas_brillig
From https://winters.com/engineering/gauge-accuracy/
"Accuracy can be expressed as percent of span or percent of indicated reading. Percent of span is the most common method with percent of indicated reading being generally limited to precision test gauges or high resolution digital gauges. Accuracy as a percent of span means that a 100 psi gauge with a 2% accuracy is accurate to within 2 psi whether the gauge is reading 1 psi or 100 psi. Accuracy as a percent of indicated reading means that a gauge with 0.1 % accuracy displaying 100 psi is accurate to 0.1 psi while the same gauge displaying 50 psi is accurate to 0.05 psi—twice as accurate."
My working career was pretty much oil & gas, primarily pipelines, so I'm guessing that the gauges I ran into were probably percent of indicated reading - which is not applicable outside of some pretty narrow bounds. Doug
Hi Guest!
