Well, last night I started to take the 1147 engine apart for the spitfire. Not a good thing. Found damage to the crank and it was already ground 30 under. Damage to the block back by the thrust bearing.(may be able to find someone to weld in metal and grind it back down) Every piston had broken rings and damage to the piston.
I am afraid that this engine block is shot. I didn't even bother to measure the bores to see if they had anything left. And I haven't look at the head to see what that needs as well. It may be easier and cheaper to find a new engine and rebuilt that. It looks like I may have to take the engine out of the Herald which has a 1147 rebuilt spitfire engine in it already and put it into the spitfire. I would then need to find an engine for the Herald.
What to do?
Engines are harder to find around here in Minnesota. Most of them are at least 200 + miles away and shipping I am sure will be a big issue.
Maybe I should go with a 1300 engine if I could find one. Is this an easy upgrade?
What do you guys think?
What to do?
