I now see why I cannot tighten the washers so they are flush against the wishbone on the right side. I seems that the smooth part of the spindle,where it meets the splines,is standing proud about the width of a thin washer so that when I tighten the bolt on the spline the top hat hits the smooth part of the spline that is sticking out. Hope that makes sense. It could be that the wishbone faces have been worn down. Is there any reason why I can't put a thin washer between the trunnion shoulder and the thrust washer to take up the slack? Also,in regard to split pins and castellated nuts.....I can see how a Nyloc washer is suitable if a nut is torqued down but if it has to be backed off till loose in order to get 4 degrees end play then wouldn't the nut only be relying on the nyloc to secure it? I know what John is saying that the whole rig isn't going anywhere and you would get notice if the bolt came loose but I tightened the 7/16 nyloc nut along with red Loctite and the next day it seemed like it didn't take all that much to break it free. Just wondering!
Hi Guest!
