GregW
Hi all,
So I've been working on getting the new parts welded into my trunk area and all the panels to fit nicely. I have to open and close the trunk lid frequently and that seems to distort the shroud where the hinge bolts to it. I think this is a pretty crappy design, so I've been thinking. I made some braces that will weld to the rear bulkhead under where the bolt hole in the shroud is. It would be attached along the back and bottom to strengthen the bulkhead where it doglegs. Has anyone else addressed this issue, what was your solution? I've also been toying with the idea of using those trunk struts. One on either side to keep the lid from tweaking.
