Hi Guest!
kalist said:Look on page 54 of the Moss catalog. Two go on the top edge of the trunk channel and two on the bottom. You should see holes in the channel where the mounting screws go.
Billm said:Are the bumpers only for the earlier cars or for later ones too?
My '65 has them.
BillM
So will it work not to have them? Also, I assume they fit in over the seal?scoutll said:The buffers are there mainly to support the boot lid when the optional or an accessory boot rack is installed. They are mounted in line to where the feet of the rack would have been. On the very early cars they discovered that the lid and hinges couldn't properly support even a light load without vibrating and causing damage. The fix was to fit thicker hinge metal and rubber buffers. I'll post some pics of the locations this evening if someone hasn't already by then.
kalist said:I installed them on my mkII with a seal from Moss and didn't have to butcher anything. They went right in.
