Re: Troubleshooting no start issues
The needle is supposed to wobble a bit, it is actually spring loaded inside the carrier (the part that fits inside the piston). The idea was to remove the requirement for it to be accurately centered in relation to the jet. Earlier carbs had a hard-mounted needle, which if not perfectly centered could cause the needle to rub on the jet enough to upset the mixture (and increase emissions). (Centering the jet is also a PITA)
But the needle is supposed to be slightly smaller diameter than the hole in the jet, so it should not stick. My guess is that the jet is full of fuel deposits. I'm not sure if this would apply in VT, but here in CA the gas we get dries into a hard, white deposit that the usual "carb cleaners" will simply not touch at all. I had a lawnmower where I literally had to chip away the deposit with a dental pick, in order to open up the main jet. Even soaking overnight in Gumout didn't phase it. And several people have had trouble with 'sticky' float valves that seemed to be due to fuel deposits.
But be careful trying to clean in there. The jet is relatively soft brass, and any damage to the bore will screw up the mixture (which is basically controlled by the open area between the needle & jet). And I don't believe the jet is readily available separately nor easily replaced.
Another possibility might be that someone has fitted the wrong needle. The 'big' TRs use .100" jets and corresponding needles, while I believe the Spitfires use .090" jets. But that would be silly, you couldn't start the engine at all ...
