banjojambo
Is it common for the vertical link to be slightly bent ? I put mine on a lathe and it looked to be out by at least 3/8 of an inch . The car was wrecked long before I got it the front end had a bad shake in it so I tore down the driver side and found one of the lower wishbones bent and the trunnion hole is slightly oval . I took the vertical link to a local machine shop they put in into a lathe and its definitely not straight . I was reading in another forum where someone posted and said they had been through a bunch of vertical links before they found a straight one
Hi Guest!
