Triumph tr3 overdrive wiring-- I am into uncharted territory and looking for a little guidance for the od wiring.
My first question:
How do I know what side is which on the switches on the top of transmission—one side black and one side yellow with a strip? Probably YP and the other B on my old harness—maybe it does not matter as long as they are same on both sides of both switches?
Hooking up-- W1 – my wiring diagram suggest A3 at fuse box or “starter switch.” I wonder if that means the push switch for start (hot side) or the solenoid (always hot side) what is most commonly used?
Hooking up--- C1—my wiring suggest control box A1-- or ammeter. What is most commonly used?
My first question:
