Re: A tool that also helps,
I got the big pieces back together last night, driving in the front and rear bearings was a bit of a challenge, I evertthing in order from the mainshaft on a rod when I took it apart, but somewhere along the line (cleaning I think) it of course got muddled up, so I put the 3rd/4th gear synchro hub on backwards and could tell things were out of whack when I got the mainshaft and first motion shaft installed.
For the record the internal part of the synchro is offset internally to one side, if I recall correctly the offset goes to the rear of the tranny, not the front, you sure can't tell from the manual pics.
In the process of working in it I managed to knock the synchro hub off the little balls twice--getting it back on while in the tranny proved to be a littel difficult (you have two hands to press three balls down, one is inaccesable at all times).
Anyway, turned out I could swap the turned around hub out by just pulling the front bearing, which of course didn't want to come out, but did eventually after much more or less friendly but forcefull persuasion.
After I put it back together the second time it all turns and shifts much better.
Yipee! Only on question, did chip some shaving of aluminum into the box while pushing the front bearing out to turn the synchro around, after all that effort to make it perfectly clean.
I am NOT going to take it all apart again, what would be a good liquid to flush it out with to get those pieces out, I was thinking gasoline (upside, relatively cheap, thin good cleaner, downside will disslove all the oil on my bearings, good for making things blow up) Marvel Mystery Oil (not as good for the job as gas but fewer downsides) or maybe one of those gallon containers of WD40. Any thoughts on the right studd would be appreciated.
Here is a shot of it with the mainshaft in. Havent tried to fit the later O/D but understand it is very straightforward compared to the early ones with all the springs.
