Post-War Other Triumph Herald/Spitfire steering rack
Michael Oritt
My 1958 Elva Courier utilizes the steering rack from a Herald which, I believe, was the same as used on early Spitfires.
Moss's catalogue only refers to parts for Mark IV Spitfires and I wonder if anyone can tell me if in fact the later Spits used a different rack from the early cars.
BTW on its website Moss sells a competition "Quick-rack" which has 2.5 turns lock-to-lock versus 3.5 for standard according to the product description. The steering on the Elva is in fact 2.5 turns and so I wonder whether the earlier racks were quicker or whether mine might have been updated with a competition rack along the way.
Any information appreciated....
Michael, as far as I can ascertain, all the Spit and Herald racks were the same. But, the quick ratio rack may have been an option.
Victoria British offers one, as does Rimmer Brothers.
Jeff
The early TR4s did have a very quick rack (about the same 2.5 turns). Otherwise, though, all Spitfires and Heralds had virtually the same 3.5 +/- turn rack. Note that the GT6 and Vitesse models had a yet-slower rack (just over four turns, ISTR).
There are two slightly differing styles of mounting the racks. The early (pre-June 1962, approximately) Herald rack utilized essentially solid mounts, while the later ones -- and all Spitfires, etc. -- used the clamps with rubber bushings. That early TR4 rack is more like the early Herald rack in terms of mounting. I suspect, though, that either type of rack could be adapted with little effort to the other type of mounting.
Spit racks are easy to hard mount, ala Herald.
The GT6 rack was 4 1/4 turns. I may pull the one out of mine and install a Spit rack. I've got three or four of those lying around.
Jeff
Andrew--
Thanks for the good information.
It's sometimes confusing trying to tie a car's parts to a timeline (for example how would the rack that was used in 1960's-issued TR 4's be available when a 1958 Elva was assembled?) and I can only assume that these alternatives existed in parts bins before they were used and were picked through by aspiring limited-production builders such as Elva. Another example is that the bonnet hinges on the Courier are the same pattern as the boot hinges for a TR4.
BTW I still have those Herald drum brakes....
Lotus also used that 2.5 lock-to-lock rack. And the hinges for the boot lid. And a Norton gascap. The "limited production" guys went for whatever was around in a quantity they needed.
I have a number of spitfire racks if you are interested...
They come from Mk ! and II combinations.. I think they are 2.5...
PM me if you wish..
r
Michael Oritt said:
Andrew--
Good question! Offhand I can't think of any Standard-Triumph product before the Herald that used rack and pinion steering. But the company that originally produced those steering racks and other suspension bits was Alford & Alder, which was by that time (or soon thereafter became) a subsidiary of S-T. And I do recall that, for example, MG used rack and pinion beginning with the 1950 TD Midgets, although those racks are a bit different (don't know who made them for BMC).
That one is easier to explain; those hinges date back to the Standard 8 of the 1950s. NOTE: original hinges from that era would NOT have had the extra little "pip" to keep them from folding over on themselves. Otherwise, both types of hinges are identical (but I don't think the original style is available any more).
