Healey Nut
So I’m trying to piece together the puzzle of linkages and rods for the throttle controls on the 62 .
Ive been referencing the two pics , one from Moss parts breakdown and the other from a nice engine bay found online .
Im pretty sure I have all the parts but the one which is confusing me is the rod that goes into that bushing mounted on the bulkhead .
I have the bushing ,and it lists the same bushing for all the 3000 series cars (item 85) . It’s rubber with a removable brass/bronze bushing .
The rod I have in my parts collection (item 60 Moss pic) doesn’t fit into the bushing in the bulkhead it’s too big . If I remove the brass/bronze bushing the hole in the rubber is a perfect fit for the rod (item 60) .But that can’t be right to just remove the bushing and have the rod sit in the rubber ?
The secondary rod which fits into the aluminum bracket on top of the centre carb is the correct size to fit in the bulkhead bushing .
What am I missing here , is it a different bulkhead bushing for the Tri-carb , do I have the wrong rod assembly .
Anybody with a tri-carb can you tell me if the diameter of the rods items 60 & 67 are they the same or is the bulkhead rod slightly larger ?
Hi Guest!
