T
Tinster
Soup,
You want a bolt with as little thread as possible
touching the metal sides of hole. Take the fork and
shaft with you to a specialty fastener shop. Play
around with different lengths.
You might have to grind a little thread off but try
to avoid that. I think heat effects the strength of
the bolt.
good luck
d
the bolt.
good luck
d
