Hello all. Looking for some much needed advice while transmission is again apart. BT7 Mk2 Centershift w/OD. Recently had tranny at a local guy's shop who was recommended by a friend. 1st gear excessive noise. He disassembled and inspected all and was not able to "see" anything wrong. He was impressed with which the fine condition of all components and we decided to put back together only replacing seals. Still has same loud grindy first gear. Then the next problem occured.. 100 miles from the reinstall, the transmission has developed a loud whine and vibration. I did a little troubleshooting and here is what I came up with. It starts to howl/vibrate around 15 to 20mph. Louder if I go faster. Does not matter what gear I am in. I can throw it in neutral, still there. I can shut of the engine, still there. I thought that because the wheels/driveshaft were still spinning at say 20mph that it might be them but I removed the driveshaft and while spinning through gears , noise is still there. Appears to be something that is on the output side as this is the only thing turning when both the car is in neutral and motor is shut off. I removed it and returned it to the tranny shop and once again, he cannot "see" anything wrong. What could he be missing and what would be the most likely culprit for both the first gear noise on a first gear that looks very good and second on the whine/vibration when coasting past 20mph. Any help or guidance would be greatly appreciated. Thanks.
