Bob Buxbaum
The most current kerfuffle. I have pressure washed the gearbox and drained the gearbox. I saw that the output shaft seal was leaking, so that is now replaced. At the FRONT end of the box, there was evidence of oil being slung out against the inside of the bell housing. SO .... I bought an input shaft seal. Then I took off the bell housing. AND, what did I find? A gasket between the gearbox and bell housing. This is a 76 Midget, and looking in the Vicki Brit catalog, depending on the serial number, there may be a seal or an o-ring. The notes at the bottom left note s/n sequences, but I do not know if that means the CAR or the gearbox. If its the gearbox, I have no clue where the S/N is. There are stickers but the numbers do not correspond to the reference info.
I have a couple of pictures that I will attach to a response to this post.
