TR6 Transmission Oil Capacity on a non OD TR-6
davidk
Does anyone know the oil capacity on a non overdrive 1974 TR-6? I haven't been able to find GL-4 oil locally, and would like to order it from TRF today while their half-price shipping sale is still on. Thanks for your help.
G
I think it is about 5 pints. Just order 2 quarts and you are safe. Better yet, order 3 quarts and you have some to replace as it drips out over the years.
DougF
According to Triumph Repair Operation Manual, 2.4 U.S. pints from dry.
G
And just what are you doing with an injection engine without an overdrive?
<span style='font-size: 11pt'>I have kept up with your posts and the injection system is cool. And pricey. Maybe that is why you don't have overdrive yet....</span>
G
Whoops. I forgot mine is overdrive. I run straight non-detergent 30 wt Valvoline motor oil.
davidk
davidk
Thanks for your help guys. Here goes another order to TRF...
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
EWD TR6 Transmission Oil Seal Triumph 13
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
TomMull TR2/3/3A Transmission oil leak Triumph 17
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
vette Transmission Oil Austin Healey 5
M What is the proper oil for Bugeye engne and transmission Spridgets 6
T Transmission Oil Austin Healey 7
R transmission and rear end oil Austin Healey 2
P TR2/3/3A TR3 Transmission oil Triumph 13
bobh Changing Transmission Oil in 10 minutes Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
T 1275 transmission oil leak Spridgets 2
M Transmission oil Spridgets 2
Jim_Gruber Transmission Oil and Differential Spridgets 3
J location of transmission oil filler on a BN-2 Austin Healey 5
PAUL161 Transmission oil Type MG 3
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
TRnorwegian Easiest way to check refill oil in transmission? Triumph 20
AUSMHLY Another transmission oil question Austin Healey 19
66healey oil for transmission Austin Healey 2
dklawson Transmission Gear Oil - Synthetic? Triumph 7
Stewart Leaky transmission oil drain plug MG 3
R Best gear oil for transmission in midget[snail] Spridgets 3
R 1500 with OD transmission oil recommendations Triumph 15
martyc MGB MGB Transmission Oil -- with Tasty Metal Shavings MG 2
ronzet Transmission Oil Recommendations Austin Healey 8
M Transmission Oil Spridgets 13
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
G Changing front oil seal on transmission. Triumph 14
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
ronzet Oil Viscosity Transmission Austin Healey 17
nevets transmission/OD oil question Austin Healey 17
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
T How full to refill transmission oil? Spridgets 4
gbtr6 Transmission Oil/Lube Triumph 4
cdsmith Transmission oil? Rear end oil? Spridgets 15
B transmission oil?? MG 10
S TR2/3/3A Tr3 transmission oil Triumph 4
Johnny Transmission oil seals Austin Healey 8
Michael Oritt Transmission oil specification--Toyota box Austin Healey 10
S Transmission oil filler where is it? MG 5
R transmission oil Austin Healey 4
G Transmission oil dilemma Triumph 6
D Transmission oil pump question MG 2
7 Transmission Oil Refil MG 3
