charleyf
I received two what I believe are TR3 transmissions with a parts car. Recently when I looked at them I realized that the numbers on them do not have a TS. Instead they are marked with 1) 10F59/ and 2) 25E59. Did the early transmissions not have a TS number and what can I determine from the numbers that I have found? I might add that the top cap on each of these has brass plugs over where the switches would go for an overdrive transmission. But these are not overdrive units. So did the early transmissions all come with the brass plugs?
Charley
Charley
Hi Guest!
