AUSMHLY
BJ8 transmission gears are quiet when car's on jack stand, loud when driven.
I've taken on the task of rebuilding the BJ8 tranny. The OD works, so I figure if it ain't broke don't fix it.
I've replaced almost all parts, gears, bearings, thrust washers, etc. On the bench, no oil, it shifts smoothly, quiet. In car with 30w non detergent oil, no drive shaft, engine at idle it shifts smoothly and relatively quietly, including neutral and clutch in. On jack stands, drive shaft spinning tires, it shifts smoothly and relatively quietly.
Driving on the road, the tranny shifts smoothly but it sounds a bit whiny in 2nd, 3rd and 4th gears, and when downshifting whiny sound is louder. I've driven the car for 15 years and this is not a sound I've heard before, and other BJ8s are quiet. Drained oil, both magnets show some fine metal, not much though. Oil looks clean, very little debris at all.
1) When car is on jacks, running at idle, no drive shaft, the coupling flange rotates. I can top it with my hand, let go, it spins again. Is that normal?
2 On jacks all gears relatively quiet with idle and 2000 rpm. Loud when driving load is on the gearbox. Is this normal?
3) I have a new clutch and throw out bearing. I noticed the release bearing on the pressure plate is blue colored. I'm not riding the clutch. Would that have anything to do with the not normal transmission sound?
