Hi all,
TR4A, overdrive transmission rebuilt by John Esposito at Quantum about seven years ago, but not run until this summer when I finished assembling the car. About 2,000 miles on it since completion.
I am getting an intermittent noise from the transmission: it sounds normal if I drive gently, shifting below 3,000 rpm. However, if I wind the engine up to 3,500-4,000, I hear a nose that sounds like marbles in a glass jar. After winding up to 3,500, the noise is present above 1,500 rpm, ie all the time when driving. Quiet at idle. The noise is not terribly loud, but loud enough to hear over everything else. If I just poke the clutch, the noise goes away (but returns upon release).
If I let the engine idle a little - sitting at a red light, the transmission is again quiet if I shift below 3,000. Wind the engine up again, marbles…
Thoughts?
Thoughts?
