Whitephrog
Started putting the transmission drain plug back in yesterday. Nice and smooth from the first couple of turns then it got very tight and hard to turn. I stopped, backed it out and inspected everything. Nothing seemed abnormal. Tried the filler plug in the drain hole with the same results.
It that normal? If not, suggestions?
Unrelated to the problem..should I use a bit of Teflon tape on the threads?
