Transmission Cooler Capacity Question
lesingepsycho
Hello all,
I have a 1971 Ford F-250 Camper Special, 360ci C-6 tranny and it has a (I believe after-market installed) transmission cooler. The other weekend as I was crossing Mt Hood with a decently heavy load (and quite frankly, pushing it fairly hard) I started losing Tranny fluid out of the filler pipe whenever I would go around a left-hander (the filler is on the passenger side so a left-hander would slosh fluid that way). That made me wonder: I presume that adding an extra cooler naturally adds volume to the system thus, how does one go around checking the fluid level? Will checking the dip-stick "when hot, in neutral" give an accurate reading or is there some other way to measure and take into account the added capacity? Thanks in advance,
JACK
It depends, what type of cooler is it? One of those
cheap azzed single tube with cooling fins type, or
is it the expensive multipath plate type??
SteveL
[ QUOTE ]
JACK
[/ QUOTE ]
Since the cooler would be full when checking the level, any additional cooler volume would be accounted for by dip-stick level. So full is still full regardless of cooler volume. It would just require more fluid to bring the level up to full.
