I think I am going to have to pull the transmission. The car often doesn't like going into second gear, and it seems to be happening more often.
Problem: Downshifting into 2nd often it like hitting a solid wall, on occasion upshifts too, but not nearly as often. Sometimes if works fine, up and down, on rare occassions it will go into gear with a big clunk.
I think I have ruled out hydraulic/clutch problems: I took up the slack in the linkage, no difference, it will shift in to all the other gears fine, never grinds going into reverse, I even tried going into reverse immediately after the end gear downshift block occured (after quickly coming to a complete stop of course), not problem, no grind.
If I slow down and shift into first it will shift into second after that fine. It will downshift into 2nd fine after I come to a COMPLETE stop, any rolling at all no go.
When I put a return spring on the clutch pedal it went away for a while so I thought it might be hydraulic (fluid return hole), but it came back and worse than ever.
So I really don't think it relates to the clutch or hydraulics but it someone really thinks they have a good argument or experiment will listen, don't want to pull the gearbox, but since the problem has only ever manifested itself in 2nd gear I am beginning to think that must be the issue, I rebuilt the box myself with all wear items synchronizers, bearings, bushings etc. replaced. (first time, maybe I just identified the issue!).
