Tranny Tunnel Knocking
Steve1970
The stress testing of the tr6 continues... After three weekends of fairly hard driving, I figured tonight I would take it out for an easy pleasure cruise. Just when I thought I shook out all the bugs... the knocking started
It's a faint knock, occurs on the right side of the tranny tunnel, just before the radio console leg. I can feel the knock with my hand on the right side of the tunnel. Seems to occur mostly in third gear around 2200 rpms.
I would venture to say driveshaft u-joint, but I had them replaced last yr when I had the gearbox out during the mighty clutch job of '08 (must have less than 300 miles on 'em). Anyhow, noise seems to be coming from closer to the radio console than the driveshaft flange Maybe the gearbox mount has come loose? Maybe the fiberglass tunnel is too small?
Anybody have a similar experience?
BobbyD
Steve.......I had a similar experience but the knocking was just behind the passenger seat. It turned out to be the u-joint hitting the side of the drive shaft tunnel under acceleration. I had to realign the diff to stop the knocking. I'd check that there was proper clearance all around the drive shaft and that tranny & diff mounts were nice and tight.
Steve1970
Steve1970
man i bet thats it. i had the diff out last yr to get access to removing the prop shaft.
so you can actually align the diff? do you just kinda shove it into place and then tighten the diff mount nuts?
thanks bob
Steve1970
Steve1970
i just read something about shaft bind/slip which can occur when the splines aren't lubed enough. basically (from what i gather), at certain loads the half shafts go into cycles of binding then slipping free, causing imbalance in the prop shaft.
can't quite remember, can the splines of the tr6 propeller half shafts be greased??? id be happy as a pig in mud if i can get away with just greasing up the splines
thanks!!
swift6
Yes, and make sure the rubber boots are in good shape to keep the dirt out of the grease.
You have to take them apart to do it.
Steve1970
Steve1970
it was a clearance issue!!
the speedo cable was sandwiched between the tranny and the tunnel, so that even the smallest level of vibration caused a knocking against the tranny tunnel walls. i've been able to push the cable slightly free from where it was lodged, but i'm sure it will find its way back to getting stuck in there again. i will need to take off the tunnel and properly route the cable to do this right.
thanks to all for the good info. with this issue resolved, and with the punishing driving over the last few weekends, i'm pretty confident that i've finally got a good straight reliable driver on my hands.
now i get to move on to the more 'fun' issues, like making it look nice. gotta settle on a color. blue vs. green? hah i wish it were that simple... mallard blue vs. french blue vs. laurel green vs. emerald green vs. conifer green... heavily leaning towards laurel green at the moment. green with redline tires, too christmas-ey??
-steve
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
stretchit2 Tranny Tunnel - Heated Opinions Austin Healey 17
pjsmetana Ok, Tranny Tunnel is Off... Triumph 14
L Not impressed with the tranny tunnel carpet Austin Healey 33
B Tranny Tunnel Heat Austin Healey 21
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
C stupid question on tranny oil Spridgets 9
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
BillyB62 Sideshift OD tranny Austin Healey 15
Griz Tranny O/D Austin Healey 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 General TR Identifing the tranny number on my j type Triumph 7
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Rut 210 tranny Spridgets 10
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
R Od/tranny 100-4 Austin Healey 6
D Spitfire '65 Spitfire MKII tranny pblm Triumph 1
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
Got_All_4 TR2/3/3A J type on a TR3 tranny Triumph 3
T TR4/4A Heat shield for tranny cover Triumph 4
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
RJS General TR Valvoline VR-1 20W-50 or Straight SAE 50 for OD Tranny? Triumph 16
Lukens TR2/3/3A TR3 A tranny questions. Triumph 8
J TR4/4A Can't get the TR4 tranny and OD to mate up Triumph 12
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
