Got_All_4
Just finished freshening up my TR6 J-type tranny gear box that is going into my TR3A. I purchased it in unknown condition. All new bearings, synchro, 3rd gear, counter shafts and thrust washers. Everything spins and shifts nicely until I put the top on. Immediately I noticed that the forks didn't line up and had to bump the top forward to get everything to drop in. Put some bolts in and tried to go through the gears. 1st and 2nd are almost locked up. 3rd gear spins the best and if I pull too far back into 4th it locks up too. I noticed that when aliening up the top the bolt holes were about a 1/2 hole off. That's when I had to bump it forward to drop it in. The problem shows up in the forks. When you place the forks on top of the shifting hubs the same half hole distance is there. I also have a 4A tranny apart that is in poor shape and if I place the top from it on the 6 tranny everything lines up and shifts fine. Unfortunately it's not a overdrive top and is not usable.
I have the shifter leaver from my TR3 in it and Scott at Team Triumph thinks it's the problem. I think I read somewhere that Randall has his TR3 shifter in his J-type tranny. correct me if I wrong.
The pic is the 2 tops together showing the difference in the fork spacing. Not sure if all TR trannys use the same forks but both of these sets have the same Standpart number on them. It's about 3/16" off.
