TR3driver
Great Pumpkin - R.I.P
Yup, that's right.ichthos said:To convert to ft/lbs with an inch/lb torque wrench, wouldn't I just multiply the value on the inch/pound torque wrench by 12, in other words would I just set the wrench to 168 inch/pounds if I wanted a value of 14 ft/lbs?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Why wouldn't I just get a foot pound wrench, since that is what I would most likely be using all the time?[/QUOTE]As Ron says, torque wrenches have a limited useful range. The lower range ones are generally marked in inch-pounds. My big wrench is only marked down to 25 ftlb, and likely isn't very accurate even there. The next smaller one is marked from 200 inlb down to 30 inlb; and the smallest one only goes up to 60 inlb.
Hi Guest!
